I'm working in ArcGIS Pro 2.7, Windows 10 Home. I am running the Data Interoperability analysis tool Workbench. I get an error when adding a reader in the FME Workbench regardless of the file input or the Python Interpreter I choose. The error is as follows:
Starting translation...
FME 2020.2.0.0 (20201027 - Build 20787 - WIN64)
Data Interoperability (node locked-crc)
Permanent License.
Machine host name is: ***
Operating System: Microsoft Windows 10 64-bit (Build 19041)
Copyright (c) 1994 - 2020, Safe Software Inc.
Safe Software Inc.
FME initialized 'Esri ArcGIS Python 3.7', but the workspace Python compatibility setting is 'ArcGISDesktop'. Please check the Python compatibility setting in the workspace
Workspace requiring ArcGISDesktop is requested to run on an FME Engine configured to use a Esri ArcGIS Python 3.7 interpreter. FME cannot continue given the Python version mismatch
A fatal error has occurred. Check the logfile above for details
Program Terminating
Translation FAILED.
Workspace generation failed. Parameter file was C:\*\*\AppData\Local\Temp\ArcGISProTemp1044\FME_1611611330791_9172.
I have tried all of the Preferred Python Interpreters, but get the same error message. It seems as though I need to change the "compatibility setting", but I'm not getting anywhere with that in my searches. Any suggestions?
