Error trying to clone Environment in ArcGIS Pro
1990
02-20-2021 08:04 PM
Teeheish_Comm
I am trying to clone an environment in ArcGIS Pro 2.7, and I receive the following error message, How to solve this error?
CondaVerificationError: The package for networkx located at C:\Users\msi-1\AppData\Local\ESRI\conda\pkgs\networkx-2.5-py37_0
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/__init__.py'
specified in the package manifest cannot be found.
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/__pycache__/__init__.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/__pycache__/asyn_fluid.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/__pycache__/centrality.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/__pycache__/community_utils.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/__pycache__/kclique.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/__pycache__/kernighan_lin.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/__pycache__/label_propagation.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/__pycache__/lukes.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/__pycache__/modularity_max.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/__pycache__/quality.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/asyn_fluid.py'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/centrality.py'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/community_utils.py'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/kclique.py'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/kernighan_lin.py'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/label_propagation.py'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/lukes.py'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/modularity_max.py'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/quality.py'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/__init__.py'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/__pycache__/__init__.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/__pycache__/test_asyn_fluid.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/__pycache__/test_centrality.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/__pycache__/test_kclique.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/__pycache__/test_kernighan_lin.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/__pycache__/test_label_propagation.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/__pycache__/test_lukes.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/__pycache__/test_modularity_max.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/__pycache__/test_quality.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/__pycache__/test_utils.cpython-37.pyc'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/test_asyn_fluid.py'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/test_centrality.py'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/test_kclique.py'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/test_kernighan_lin.py'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/test_label_propagation.py'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/test_lukes.py'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/test_modularity_max.py'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/test_quality.py'
appears to be corrupted. The path 'Lib/site-packages/networkx/algorithms/community/tests/test_utils.py'
DanPatterson
MVP Esteemed Contributor
I would verify that  networkx works in the environment you are trying to clone.
networkx-2.5-py37_0 is the package.  It might be worth cloning without that package and trying to install it separately or reinstalling it in the source environment
... sort of retired...
Teeheish_Comm
Thanks, @DanPatterson, I tried another way, I copied the default python environment to conda environment, renamed it, then afterward I went to manage environment in ArcGIS pro to select the copied environment as a clone, and it worked nicely...
