Error Spacing for elements in Map Layout when upgrading ArcGIS Pro 3.0 to ArcGIS Pro 3.3.1
1808
6
08-11-2024 08:41 PM
Sothea_VOEUN
Hi to all ArcGIS Pro Users,
Recently, I encountered some inconveniences when opening the ArcGIS Pro Project. Because I upgraded my ArcGIS Pro from the 3.0 version to the 3.3.1 version, the elements in the map layout (map legend, text, map title, etc.) were changed unmannerly. Please take a look at the issue below.
I was looking for any solutions to deal with this issue.
I look forward to getting ideas!
Thank you!
@JesseCloutier @AmirBar-Maor
JesseCloutier
Esri Community Manager
Hi @Sothea_VOEUN, I'm a Community Manager for the Esri Community platform specifically and am not equipped to answer your ArcGIS Pro question or I'd be happy to help. Will leave this for @AmirBar-Maor or others in the Community to assist with. All the best!
Jesse Cloutier
Community Manager, Engagement & Content
Sothea_VOEUN
Thanks for taking your time, @JesseCloutier
It seems like the ArcGIS Pro itself got some improvements when upgrading from the lower version to the most up-to-date version.
AubriOtis
There were some updates made in recent releases to how text is handled in ArcGIS Pro to better support text positioning and provide more correct experiences. In some cases this changed the spacing and positioning of text elements slightly. I think you may be experiencing that. You should be able to adjust the spacing between the lines of text to achieve the original look and feel. I'm so sorry for the trouble, while this overall is an improvement, there were some side effects.
Cheers,
Aubri
Sothea_VOEUN
Do you mean that the most decent approach is to manually adjust that spacing?
AubriOtis
Yes, at this point the best approach is to manually adjust the spacing.
Cheers,
Aubri
Sothea_VOEUN
Thank you for your answer.
