Error in Detect Object Using Deep Learning Model
1564
04-27-2023 08:37 AM
AdityaS
Hello community Please help me with my deep learning Object detection. I already trained the deep-learning model using ArcGIS pro-environment and the results and model characteristics are attached here. After training the model when I use Detect Object Using the Deep Learning tool, I find Errors every time I run the model on a different image and with different thresholds and other parameters.
ERROR 160722: The item was not found.
PavanYadav
@AdityaS are you still experiencing this issue? if yes, is it possible for your to share the model and ArcGIS Pro version?
A side note: We have an ArcGIS Image Analyst dedicated community and here you might get response sooner on imagery related questions.
Cheers!
Pavan Yadav | Product Engineer - Imagery and AI
Esri | 380 New York | Redlands, 92373 | USA
https://www.linkedin.com/in/pavan-yadav-1846606/
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
