Error: Cannot retrieve attribute.
2490
10-04-2023 10:24 AM
AmyRoust
I have a step in a task that uses Calculate Field to change the value of one field in one record of a table in a file geodatabase. After it calculates, I want to copy that value from the table and assign it to a variable to use in a future step. However, when I set up an action under "When exiting the step" to Copy attributes from Feature or record modified in this step, I get the error message: "Error: Cannot retrieve attribute. Unable to retrieve selection modifiedInStep." Can anyone help me fix this?
MichaelVolz
Esteemed Contributor
Have you consulted ESRI tech support with this issue to see if it might be a bug with tasks?
AmyRoust
Not yet. I'm brand new to tasks, so I thought I'd ask around first to make sure that I wasn't making a rookie mistake. I'll probably call tomorrow if I don't get any ideas here. Thank you!
