error calculating geometry
2642
11-19-2020 02:14 PM
AnastasiaStats
I am trying to calculate geometry for a set of polygons and find their area. At first I was getting an error that said "Failed to apply changes after updating the row with objectID=0 with the calculated value" and it would only give me 5 areas out of 39. Then I hit start editing and tried again and this time values populate but it wont let me save them due to a row error. Any guidance is appreciated because I don't know what could be wrong with my rows.
DanPatterson
MVP Esteemed Contributor
Try your calculate geometry outside of your edit session.
You should run a Repair Geometry tool when you are done editing and before any calculations as well
... sort of retired...
imansbburg
Can anyone help me with this error? I'm on ArcPro 2.9
File "c:\arcpro\Resources\ArcToolbox\scripts\calculategeometry.py", line 276, in <module>
CalculateGeometry(fc, properties, lUnit, aUnit, cs, cformat)
File "c:\arcpro\Resources\ArcToolbox\scripts\calculategeometry.py", line 125, in CalculateGeometry
ucur.updateRow(row)
SystemError: <method 'updateRow' of 'da.UpdateCursor' objects> returned NULL without setting an error
JuneAcosta
HI. Did you get this issue resolved? I'm getting the same error message when running the "calculateGeometry" tool from ArcGIS Pro. 3.5.1.
AnninaHirschiWyss
same here in Pro 3.5.4 and 3.6.0...
(Trying to update 3D Length in ArcGIS Indoors Transitions)
