Error 999999: Export Features from an Route Event Layer
2115
07-04-2024 06:45 AM
mayettea
Hi! I have been slowly transitioning from ArcMap 10.8 to ArcPro and I have an ongoing GIS project. One of my steps is to Locate Features Along a Route. With ArcMap, I was able to then Make a Route Event Layer and export as a shapefile, but with ArcPro, I get an error message when I'm ready to export to a shapefile.
The operation was attempted on an empty geometry.
Failed to execute (ExportFeatures).
I'm aware there are some of my Event points that have an empty geometry and it was never a problem with ArcMap to still export. Is there a way around this or do you suggest another way to save my Event Layer? In the future, I would like to be able to do all my geoprocessing in ArcPro and not have to use ArcMap for one step, especially considering it's going to be discontinued.
Thanks!
2 Solutions
DanPatterson
MVP Esteemed Contributor
query for the non-empty geometry records, then export since selections will be used and other records ignored .
... sort of retired...
Bud
Legendary Contributor
It would help if you could report this issue to Esri Support. Esri considers Error 999999 to be a bug and they strive to fix those issues in future releases.
DanPatterson
mayettea
Thanks @DanPatterson for the suggestion. I did try that but it would tell me that it doesn't recognize the column name. I opened a case with Esri Support and it seems it might be a problem in the structure of the data before I get to this step.
Bud
mayettea
I did contact Esri Support and I have now an open case, thanks!
