Error 1311 when installing ArcGIS pro
11913
04-30-2023 11:36 AM
AssemAlalim
Hi
I am new with the platform. I am unable to install ArcGIS Pro, i went through the process with Run Checksum and when installing i get a message later Error 1311. Source file not found, and it does not complete the installation.
Can someone help ho to install ArcGIS Pro
Thanks in advance
P.s. screenshot attached
Tags (1)
2 Solutions
DanPatterson
MVP Esteemed Contributor
move the downloaded *.exe and the extracted *.msi and *.cab file into a simpler folder (like c:\Temp) and double-click on the *.msi to try the reinstall again.
... sort of retired...
DavidPike
MVP Notable Contributor
I would definitely take the installer out of your OneDrive location and retry.
DanPatterson
AssemAlalim
Thanks it was the one drive location  creating the issue
DavidPike
AssemAlalim
Thanks it worked
