ERROR 001249: Cannot package result
8419
12
07-08-2022 10:01 AM
VerleyAltamirano
Hey everybody,
I am having problems with the publication of a geoprocessing service, no error appears when performing the analysis but the tool shows me the following detail:
StatusMessage: Using ArcGIS Version 12.8 for staging (Source for version: GP Staging Parameters)
ErrorMessage: Consolidation failed
ErrorMessage: ERROR 001249: Cannot package result
I can't find any documentation about it. I appreciate your help.
LukasHoupt
Weirdly enough, worked for me when I restarted ArcGIS Pro and did not analyze first
AlexanderCapellan
Esri Alum
For some reason, after restarting ArcGIS Pro and not analyzing as suggested above, the geoprocessing service was published.
GEORGIOSCHALARIS
I have come across the same situation some times.  If you work with  models that are being published as web tools,  my advice is to check if you have put the outputs of the tools as parameters.
In general be very cautious how you setup the parameters in a model. Analysis maybe fine, running fine, but publishing fails in the staging phase.
