ERROR 000229: Cannot open temp_layer Failed to execute (PointToRaster).
3479
04-15-2023 09:31 AM
AlexanderZirilli
Hi. Just wondering if anyone could tell me what's wrong with the temp_layer here? I am using the temp layer to avoid problems with the PointToRaster_conversion and data sources with joins. (error 000055)
import arcpy
from arcpy.sa import *
arcpy.env.workspace = r"C:\Users\aazma\Desktop\Incomplete(503)\Incomplete"
arcpy.env.overwriteOutput = True
in_csv = r"C:\Users\aazma\Desktop\Incomplete(503)\Incomplete\PCBsData.csv"
out_raster = r"C:\Users\aazma\Desktop\Incomplete(503)\Incomplete\output.tif"
layer_name = "temp_layer"
x_field = "X"
y_field = "Y"
spatial_reference = arcpy.SpatialReference(4326)
arcpy.MakeXYEventLayer_management(in_csv, x_field, y_field, layer_name, spatial_reference)
cellsize = 0.1
value_field = "value"
assignment_type = "MEAN"
arcpy.PointToRaster_conversion(layer_name, value_field, out_raster, assignment_type, value_field, cellsize)
arcpy.Delete_management(layer_name)
Tags (1)
DavidPike
MVP Notable Contributor
Have you tried the "memory" example?  You're currently writing to your desktop/user data folder, there could be organisational or personal setup restrictions on executables writing to this location so I'd also try a folder within a drive e.g. C:\Testing\Testing.gdb
I'd also always try the script on a very small subset of data initially.
DavidPike
I'd say it's having an issue accessing the layer, parentheses in the workspace path could be an issue.  Maybe write to memory or try a different workspace path, or make the temp location explicit.  psb writing to memory example:
import arcpy
layer_name = r"memory\temp_layer"
x_field = "X"
y_field = "Y"
cellsize = 0.1
try:
  del layer_name
except:
  pass
AlexanderZirilli
Added the recommendations, and removed the underscore from temp_layer, as pictured. any other ideas? my dataset is also many years of time, so potentially splitting the data into years and then processing could help? I couldn't find anything about file size limitations online but just an idea.
import arcpy
arcpy.env.workspace = r"C:\Users\aazma\Desktop\Incomplete503\Incomplete"
in_csv = r"C:\Users\aazma\Desktop\Incomplete503\Incomplete\PCBsData.csv"
out_raster = r"C:\Users\aazma\Desktop\Incomplete503\Incomplete\output.tif"
layer_name = r"C:\Users\aazma\Desktop\Incomplete503\Incomplete\templayer"
x_field = "X"
y_field = "Y"
cellsize = 0.1
try:
del layer_name
except:
pass
DavidPike
AlexanderZirilli
I tried a sample .csv of only a few lines, and that worked. So then I split the data up into 2001.csv, 2002.csv, etc and found that I got the same error. because of this I simply shortened each year to 150 samples, and cleaned a few columns I didn't end up using, and this worked. Below is the final version of the code, thank you for all the help!
import arcpy
arcpy.env.workspace = r"C:\Testing"
in_csv_list = ["2001.csv", "2002.csv", "2003.csv", "2004.csv", "2005.csv", "2006.csv", "2007.csv", "2008.csv", "2009.csv", "2010.csv", "2011.csv"]
for in_csv in in_csv_list:
out_raster = in_csv.split(".")[0] + ".tif"
layer_name = r"C:\Testing\templayer"
x_field = "X"
y_field = "Y"
cellsize = 0.08
value_field = "Total_PCB(ppm)"
assignment_type = "RANGE"
del layer_name
