Enterprise geodatabase connection slow - machine running SQLServer using 84% memory
2671
7
09-24-2025 02:19 PM
imansbburg
I've been having painful performance issues connecting to my enterprise geodatabase, and upon finally remote desktop'ing to the machine running SQLServer instance that houses the database, I find that it's using a high percentage of memory.
Normally I consume our data through the map and feature services published as references to this SDE and don't have a problem, but I had some changes to make in the database itself (adding a layer, registering as versioned) hence connecting directly and trying to hit the 'manage' tab.
What are the best practices for running any kind of reboot or health-checking on the SQL server data source?  We are on SQL Server 2022 and Enterprise Portal 11.3
DerekLaw
Esri Esteemed Contributor
Hi @imansbburg,
Please take a look at this help topic, Enterprise geodatabase maintenance tasks.
Hope this helps,
imansbburg
Thank you. I do have a weekly script for compressing the database and rebuilding indexes-- the task manager showing me high memory use got me wondering what else I can check.
DavidPike
MVP Notable Contributor
I'd do the normal reports on blocking transactions etc. you would for a normal DB also.  If people are consuming tables directly from the database, look out for stuff like missing spatial indexes on big datasets.
VenkataKondepati
Honored Contributor
A few check points.
  • Memory/Resource Monitoring – SQL Server will grab as much memory as it can. Use SQL Server Management Studio (SSMS) to check Max Server Memory settings. By default, it may be consuming everything — leave some headroom for OS/ArcGIS components.
  • Regular Index/Statistics Maintenance – rebuild indexes and update statistics on heavily edited feature classes. This keeps query plans efficient and reduces sluggishness in ArcGIS Pro/Manage tabs.
  • SQL Server Agent Jobs – schedule nightly index rebuilds and database consistency checks (DBCC CHECKDB) as part of your health routine.
  • Reboot Cycle – not usually required often, but if you see memory pressure or long-running connections stuck, a controlled restart during a maintenance window can help clear the cache.
  • ArcGIS-Specific Checks – use sdecommand or Pro’s Analyze Dataset tool to check for schema locks, invalid states, or orphaned versions.
  • Baseline Monitoring – ArcGIS Monitor or SQL Profiler can help you pinpoint if the bottleneck is at SQL I/O, CPU, or query design.
Regards,
Venkat
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
DavidPike
Thanks ChatGPT
VenkataKondepati
Honored Contributor
Hi @DavidPike,
Thanks for alerting me to not use ChatGPT.
I was using it to format my response and enhance it. I noticed that it is adding some additional unnecessary information.
I will look into it next time.
Regards,
Venkat
Regards,
Venkat
imansbburg
My IT folks took a look at the machine running SQL server with the database, and did all updates /rebooted, but I still run into the same crippling freeze up when I try to get to the 'manage' menu for a specific feature dataset. It's a dataset I had added a new feature class to, and then I needed to re-register the dataset as versioned. How am I supposed to accomplish this?
