Elevation issue
1098
07-14-2025 02:06 AM
SumaliAbeyrathne
Hello, I am integrating a 3D Revit model into ArcGIS Pro for a GIS/BIM project. After importing the model, the ground floor foundation sinks below the ground surface although everything appears correct in Revit. Unfortunately, the elevation editing options are disabled in ArcGIS Pro, and I cannot adjust the model’s vertical positioning within the tool.can anyone help with this?
SumaliAbeyrathne
After importing the model, the ground floor foundation sinks below the ground surface  and the elevation editing options are disabled in ArcGIS Pro. can someone help with this?
SumaliAbeyrathne
Hello, After importing the model, the ground floor foundation sinks below the ground surface and the elevation editing options are disabled in ArcGIS Pro.can anyone help with this?
DA_BIM-GIS
Hello @SumaliAbeyrathne
What tool are you using to adjust the elevation? My recommendation is to follow the workflow described here. https://www.esri.com/arcgis-blog/products/arcgis-pro/aec/geolocating-a-digital-model-revit-or-ifc-in...
David
