Editing Issues in GIS PRO
7814
16
05-16-2024 04:41 PM
shaunman2
Many times I am in a editing session and my edits quit showing on the map. I will draw a feature line from a meter to a pipe and it will disappear! I will edit vertices but the edit will not show until I exit the program and then open pro again and then I see my edits and lines I tried to add. I have read about cache and tried changing cache settings to no avail. I am fairly knew to GIS after being a civil 3d designer for many years and have been given this great opportunity, but this is driving me crazy! I even started a project over hoping this would purge out the bug. If you can offer me some advice I would truly appreciate it.
Eugene_Adkins
The only thing I could suggest, with my experience, would be to create a completely new ArcPro project, create new connections to your database(s), add the layers you edit from your connection, and see if the issue persists.
If the issue does not persist then that would mean there is an underlying issue (probably next to impossible to identify the exact reason) with your “old” aprx. If the issue persists with the new aprx, then this would mean there is an underlying issue with the data which could probably be identified but it would require assistance from tech support via a screen share so the support technician could more specifically identify the data setup and hopefully the root cause of the issue.
NaowarahAlanzi
NaowarahAlanzi
Hail
shaunman2
I had already tried that to no avail, but I saw I had a 3.3 patch available and had IT install it and it has solved a lot of my issues. I can now edit and see my edits (Yay!), there are still a couple of glitches such as attribute table once in a while has to be reloaded if I have had it open for a while and the program freezes once in a while but I am ecstatic about being able to see my edits and not having to exit and reload to see them. Thanks to everyone for your assistance with this long term problem, it has been a great experience hearing from all of you, and your efforts have been very appreciated and 3.3 patch is awesome!!!!!!!!!!
RTPL_AU
This is one of the 3.3 things that drives me crazy. And people wonder why I still use ArcMap if I want to get something done quickly.
RTPL_AU
@KoryKramer  I am sure I spotted this behaviour in a release notes or something as a resolved issue. I never had this until I upgraded to 3.3 / 3.3.1, so is it still a known and worked on problem?
RTPL_AU
@shaunman2 @Eugene_Adkins  This seems to happen most often when the layer edited is being projected i.e. it is in a different coordinate system than the map.
EDIT:
Also when layer is in same coordsys as map so this may just be a coincidence.
