Edit Vertices Broken ArcGIS Pro 2.7.2
2778
03-15-2021 01:39 PM
CheyneHadley
Since updating Pro to 2.7.2, it seems that the Edit Vertices tool has broken.  Trying to edit a vertex will rotate and scale the feature around the starting point.  The tool is supposed to allow me to move the single vertex independent of other vertices around however I want.
@KoryKramer
#help please‌ #need fix
KoryKramer
Esri Community Moderator
KoryKramer
CheyneHadley
Ok, that fixed the problem.  I feel silly now, but then again, I've never used that feature.  Thank you for the quick reply.
KoryKramer
No need to feel silly.  There are a lot of different settings - I'm just glad that it was a quick and easy solution rather than a bug!  Cheers.
