ECW File conversion
17196
03-28-2019 10:08 AM
DipanwitaDutta
How to convert a ECW file in TIFF? I do have ArcPro in my computer and I tried to use the tool "raster to other format"", however, the software could not recognize the ECW file. How can I proceed?
MatthewDriscoll
It might have do with what version the ECW is.  Here is an old thread I came across when I was having the same problems.
George_Thompson
Esri Notable Contributor
You should be able to ECW in ArcGIS Pro; https://pro.arcgis.com/en/pro-app/help/data/imagery/supported-raster-dataset-file-formats.htm
What version of ArcGIS Pro are you using?
--- George T.
econgu
You can do this by right-clicking the raster file in your Contents tab, and choosing Data --> Export Raster. I believe the output format is automatically set to TIFF.
VickyWang
Copy Raster geoprocessing tool (same function as Export Raster that @econgu mention above). It gives you some flexibility to put into python or Model builder for steam line or automate the process.
~Vicky Wang~
