Easily move a feature on only one axis
3028
02-09-2022 09:33 AM
MatthewLaw_MM
Is there an easy way to restrict the movement of a feature to only one axis when moving it manually in ArcGIS Pro (ie via Edit --> Tools --> Move)? In PowerPoint, for example, holding down the shift key while you're moving a textbox/shape/image/etc restricts the movement so that the feature will only move either up/down (with no movement along the x axis) or left/right (with no movement along the y axis). I know there are ways to do this which involve specifying a certain distance and direction to move the feature, but a simple way to do the same thing (akin to the PowerPoint functionality) would be really useful.
Scott_Harris
Hi @MatthewLaw_MM
You can do this easily enough with the editing grid turned on:
  1. Turn on the Grid
  2. Select features with Move
  3. Hold Ctrl to snap the move anchor to a vertical or horizontal grid line
  4. Move the selected features vertically or horizontally while snapping to the same grid line.
 Requirements:
  • Snapping turned on.
  • The "snap to grid" snapping option turned on.
Other ideas:
Align or Distribute https://pro.arcgis.com/en/pro-app/latest/help/editing/align-or-distribute-features.htm
Move To using the Delta method: https://pro.arcgis.com/en/pro-app/latest/help/editing/move-a-feature-to-specified-location.htm
-Scott
Scott_Harris
Hi @MatthewLaw_MM
  1. Turn on the Grid
 Requirements:
Other ideas:
-Scott
MatthewLaw_MM
Thanks @Scott_Harris, that's just what I was looking for!
