Dynamic text value with SQL Expression return first record
2226
01-18-2023 06:44 AM
ZacharyHart
Honored Contributor
Experimenting a bit with dynamic text and table attributes which is listed as 'value' in the dynamic text dialog.
I see you can use a few options that would limit the resulting return for 'All records', 'Visible records', and 'Custom Query'. The custom query expression uses SQL and would have a default of something like: sql="OBJECTID = 1". You can use the SQL expression builder but unfortunately it does not recognize table names which is unfortunate.
A typical dynamic text may look like this:
<dyn type="table" property="value" mapFrame="Main Map Frame" mapMemberUri="CIMPATH=location_map/forest_types.json" sql="OBJECTID = 1" arcade="&apos;CLIENT: &apos;+$feature.CLIENT" delimiter=" "/>
I'd like to be able to use an SQL statement to return only the first record but not having any luck.
SELECT FIRST(column_name) FROM table_name;
Is any of this possible?
KariBuckvold
did you ever figure this out? I would really like to do this as well!
ZacharyHart
Honored Contributor
Supposedly the Arcade Distinct function will be working in the 3.2 release...(several years after it was first shown in the documentation).
You can read comments from others here.
KariBuckvold
thanks for the reply, @ZacharyHart ,too bad we can't use python and use 'set' in the meantime.
