Duplicate lines
3586
7
03-20-2024 08:33 AM
SLouq
by MVP Alum
I am trying to edit a polyline in ArcGIS Pro but whenever I make an edit to the line, a duplicate of the line suddenly pops up in my map showing the edit I made in a different location and when I save my edits the line jumps to the wrong location. What is going on?
4 Solutions
Eugene_Adkins
Looks like some sort of transformation/projection issue on the data. Perhaps the edited data is being projected on the fly, but when you make an edit the "on the fly projection" is being overridden by the underlying coordinate system applied to the data.
It's an idea anyways.
Eugene_Adkins
Does it happen with every project or only the current project you’re using?
Eugene_Adkins
I would check the coordinate system then. I’ve had something similar happen to me. If it doesn’t happen in other projects it’s not the data (apparently) and if it’s not a projection issue then there’s something funky with the aprx itself.
SeaRM
I think it's a snapping problem. Your line snaps to the closest feature.
Eugene_Adkins
SLouq
by MVP Alum
It's weird cause I don't remember this happening to me before and I've worked on this feature before.
When select the line and click Edit Verticies, the line becomes editable with the verticies on it and the duplicate line disappears. But once I make my edits and click the green checkmark to apply the edits, the duplicate line pops up.
Eugene_Adkins
SLouq
by MVP Alum
Just noticed it in this project.
At first I thought it might be something with a duplicate features setting turned on or something but I looked and I didnt see anything with duplicate features
Eugene_Adkins
SLouq
by MVP Alum
It's possible it could be the coordinate system.
I have the line feature in a map with other hosted feature layers, I'm bringing in from my ArcGIS Online acct and the line feature is in a different coordinate system than the Hosted Feature layers.
Thanks for your suggestions!
SeaRM
