Drawing points with depth less than 100km
1562
06-02-2021 12:14 AM
Oretana_
Hello,
I have a table with data related to earthquake and I would like to show in a scene. When I have tried to create a point feature layer, the points with depth less than 100km are not draw because they go outside the vertical datum limit (I am using WGS84).
Could I change this limit somehow and put it for example as -200km?
Thanks in advance.
Oretana_
Dan, thanks for your response.
Finally,  I found the solution by changing the parameter in the environment of ArcGIS Pro. The default value is 100000m and -100000m and I changed as show in the image below:
DanPatterson
MVP Esteemed Contributor
Would a projected coordinate system for your area of interest remove that limit?
... sort of retired...
Oretana_
