Dissolve / Pairwise Dissolve generates error
10920
11
06-11-2023 03:50 PM
Mikhail
I have a shapefile with small polygons, that I need to merge into larger ones. Merging should be by a specific variable, conparid, which is available for any polygon. I am trying to use the 'Dissolve' and 'Pairwise dissolve' tools, but receive a message 'WARNING 000117: Warning empty output generated'. I successfully ran 'Repair Geometry' and 'Check Geometry', but this did not help.
Eventually, I simplified my dataset to include only two polygons, which I am trying to merge. Please see the screenshot attached. I wonder what could be wrong, and would appreciate any suggestions.
Tags (3)
Mikhail
Fantastic, it all worked! The interesting thing is that the output of Dissolve looks very much like a shapefile. I can see the merged polygons on a map...I wonder why I did not have to do the last bit and convert the geodatabase to a shapefile?
DanPatterson
MVP Esteemed Contributor
Perhaps you could "Accept as Solution" the thread that provided the answer so that it can be discovered by others in your situation
... sort of retired...
