Do we have similar functionality in ArcGISPro?
By default, ArcMap displays the coded value domain and subtype descriptions in the attribute table. The instructions provided below describe how to display the coded value domain and subtype codes instead of their descriptions.
I am looking for the same functionality in ArcGIS Pro 3.0.
Kindly suggest
It's in the menu of the attribute table:
R_
R_
Hello! The reply here provides useful information to turn off the decription (that is, to display the coded domain value without the description) for a singular table. I'm looking for a way to turn off the description by default (for all tables and all projects) like we were able to do in ArcMap as mentionned above. Anybody knows a way to get this done? Thank you very very much and have a good day!
Alex
Those following this thread, please add your kudos to this Idea if you would like to see the ability to choose a default behavior: https://community.esri.com/t5/arcgis-pro-ideas/set-as-default-display-only-coded-values-from/idi-p/1...
Thank you
Is it possible to show the Code for only one field and not the rest? And for this behavior to carry all the way through to the REST service and map viewers and Field Apps?
