Display Coded value from Domains instead of Descriptions (vice versa) - ArcGISPro
9220
07-27-2022 02:15 AM
User35489
Do we have similar functionality in ArcGISPro?
By default, ArcMap displays the coded value domain and subtype descriptions in the attribute table. The instructions provided below describe how to display the coded value domain and subtype codes instead of their descriptions.
  1. In ArcMap, navigate to Customize > ArcMap Options > Tables.
  2. Uncheck the 'Display coded value domain and subtype descriptions' option
I am looking for the same functionality in ArcGIS Pro 3.0.
Kindly suggest
RhettZufelt
MVP Notable Contributor
It's in the menu of the attribute table:
R_
RhettZufelt
R_
AlexBouchard
Hello! The reply here provides useful information to turn off the decription (that is, to display the coded domain value without the description) for a singular table. I'm looking for a way to turn off the description by default (for all tables and all projects) like we were able to do in ArcMap as mentionned above. Anybody knows a way to get this done? Thank you very very much and have a good day!
Alex
KoryKramer
Esri Esteemed Contributor
Those following this thread, please add your kudos to this Idea if you would like to see the ability to choose a default behavior: https://community.esri.com/t5/arcgis-pro-ideas/set-as-default-display-only-coded-values-from/idi-p/1...
Thank you
Kevin_MacLeod
Is it possible to show the Code for only one field and not the rest?  And for this behavior to carry all the way through to the REST service and map viewers and Field Apps?
