Disable contigent values on ArcGIS Pro
830
05-14-2024 10:51 AM
Labels (2)
EmilianoPetrelli
Hi all,
I'm trying to find a way to disable contigent values on editing a feature layer  on ArcGIS Pro while use them on editing the same feature layer on WebMap/Maps SDKs App (Javascript in my case).
This because in ArcGIS Pro you cannot create the geometry starting from a default template before correct the wrong values so the process it seems to be:
  1. Select the template (you can notice a red stop near the template suggest you that some fields value are invalid)
  2. correct the values on the template panel
  3. digitize the geometry
  4. finish sketch
This, in my opinion, is not as intuitive as the workflow on the WebMap editing where you can create the geometry then check the fields values marked as invalid by Contingent Values.
So should be great if there an option somewhere con ArcGIS pro allow the user to ignore contingent values if presents.
Anyone can help me?
Thanks in advance
Emiliano
