Detect Objects Using Deep Learning error
4801
01-26-2021 12:20 AM
TAN860421
Hello. I am a newbie about deep learning and I was trying to run the "Detect Objects Using Deep Learning" tool to detect palms in a tiff aerial image an I got an error (see below). I'm using ArcGis Pro 2.7.
I followed the workflow successfully, meaning that I created the labeled objects, trained the model - no errors at these stages. When I tried to run the "Detect Objects Using Deep Learning" tool I got the following error message:
"ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Unable to prepare input raster(s) for the python raster function.
The specified non-optional parameter doesn't have a value. [rasters]
Failed to execute (DetectObjectsUsingDeepLearning)."
In order to export the training data of Faster RCNN, I used the metadata format: KITTI_rectangles, but the problem as I mentioned was not able to run the last tool (detecting objects)
Can you help me please?
emd
by Anonymous User
Not applicable
HI,
I see you have trained an object detection model, you need to use the tool "Detect Objects Using Deep Learning". Let us know if you still face any issue with that.
Sandeep
by Anonymous User
Not applicable
HI,
Sandeep
TAN860421
That's right, this tool should be used in the correct way, thank you.
Kris_AB
I used pretrained model for building footprints. same message came and detect object using deep leaning tools failed. any suggestion?
