Destination layer is not showing up in the paste special window
2370
10-23-2022 06:49 PM
Ali_Shojaei
I am trying to copy/paste special from one layer to another in ArcGIS Pro 3.2. But the destination
layer is not showing up in the paste special window.
Any help is appreciated.
Ali
HassanEljaji
Hi Ali,
Another option is to use the Copy in the Data Management geoprocessing tool to make a copy of the input data.
* If a feature class is copied to a feature dataset, the spatial reference of the feature class and the feature dataset must match; otherwise, the tool will fail.
* The Copy tool does not support copying a network dataset back into the same geodatabase.
If that fails, a reboot of the program could free the virtual memory that might cause the copy/past special process to fail.
CarlMorrison
May I ask, are you attempting to copy features using editing tools from one feature class to another?  Can you check that the destination feature class is check marked to allow editing and is visible?
