Deploying Adopt-a-Catch Basin Solution
1513
11-18-2020 07:41 AM
GISManager4
Deploying the Adopt-a-Catch Basin Solution from ArcGIS Pro, when I performing the Set up user table task>copy user table to a database registered to ArcGIS Enterprise, I received the following error:
000210: Cannot create output <value>.
Description
The output cannot be created. Potential reasons include data locking, an incorrect path, and limited access rights.
Solution
Confirm that the data is not locked by another user or application and that you have full rights to the workspace being used. Check to make sure that the path to the data is correct (check for typos in the folder path). Try creating the output in a new location.
