Deleted
1867
6
07-11-2020 10:42 AM
tt1
Deleted
DavidPike
MVP Notable Contributor
It worked for me in arcmap, unless there's an environment setting, you have a selection applied on the dataset it would appear to be a pro issue. (I cant test it in pro).
DanPatterson
Were the originals shapefiles?
Did you try them as featureclasses in a geodatabase if they were?
... sort of retired...
LukasFalk
Hey there,
I attempted to download the data for testing but it looks like the folder is in your trash bin.  Perhaps make this available again and I can do some testing within ArcGIS Pro.
Thanks!
tt1
Hi Lukas, is there any way to delete this reply? It contains the personal information of a colleague. Thanks.
LukasFalk
Hello t t
The screen shot has been deleted.  My apologies.  If you could upload the data in another way I'd be happy to look into your original issue.
Lukas
tt1
It turns out there was an error when changing the CRS between layers but many thanks!
