Deleted Survey123 Data
660
12-04-2024 04:07 AM
Labels (2)
jtl2016
Hello all,
I converted my Survey123 form into a web map and opened those feature layers into ArcGIS Pro desktop. I thought I was good to work independently from there. Turns out, the attribute data I deleted effected the host layer and therefore my Survey123 data. I'm confident I can recover this, just not sure where to begin.
Additionally, I do have these files exported into excel, is there anyway to reupload this data to survey123? I am in collaboration with some people, so I need to get this data back on.
RyanUthoff
MVP Regular Contributor
So as long as you didn't delete the actual record and only the attribute data, you can just join your Excel file to the feature layer in ArcGIS Pro, and then just recalculate the fields. Of course, that's assuming you have a unique ID field that can be joined between the two. That's probably going to be the easiest and simplest way of doing it.
