Deleted feature shows up on exported map
2187
10-12-2021 08:46 AM
Cnbudwick
I've deleted a feature on my map and isn't visible anymore, which is good. However, where I go to export the map the feature reappears on the exported png? why is this happening?
JoeBorgione
Try removing the data from your project and then add it back in.  I'm not sure what is going on, but it seems like a caching issue. You can go into the Options pane and check your cache there as well and clear it manually.  Here is a shot of mine, and I might want to clear it...
That should just about do it....
ToryKurlander
this worked for me thank you!
