Default sort order in Pop-up pane
800
11-08-2023 08:03 AM
aretzler
Whenever I select a layer element in the Pop-up pane and assign a sort setting (i.e., Sort Ascending), this setting only seems to be applied for this one instance. If I re-select the same features or other features within the same layer, the sort order returns to Sort by data by default. Is there a way to change the default Pop-up sort order setting? I would like to maintain the Sort Ascending setting throughout my work in this ArcPro project and not have to change the sorting every time I use the Explore tool.
