Deep Learning- Object detection
987
11-10-2022 04:43 AM
DiegoErnestoFarfn
Good morning everyone, I'm new to using deep learning tools. I am trying to use these tools for plant counting from drone obtained orthomosaics.
When implementing the Single Shot Detector (Object detection) model in Arcgis Pro 2.9, the error ERROR 032659 updateParameters Error: Traceback (most recent call last) occurs:
  File "c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx\TrainDeepLearningModel.tool\tool.script.validate.py", line 653, in <module>
  File "c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx\TrainDeepLearningModel.tool\tool.script.validate.py", line 287, in updateParameters
    backbone_list = training_model._supported_backbones()
  File "C:\Users\Usuario\AppData\Local\ESRI\conda\envs\deeplearning\lib\site-packages\arcgis\learn\models\_ssd.py", line 368, in _supported_backbones
    *_resnet_family,
NameError: name '_resnet_family' is not defined
The error disappears when I select the model ¨YOLOv3 (Object detection)¨ or ¨MMDetection (Object detection)¨. However, a new error arises,
  File "c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx\TrainDeepLearningModel.tool\tool.script.execute.py", line 121, in <module>
    class ProgressCallback(Callback):
NameError: name 'Callback' is not defined
Has anyone been able to fix these errors?
From now, thank you for you help!
DaniMahardikaSuroso
Hi Diego,
I've try to read the tool.script.execute.py on that code there's line with
 from fastai.callback import Callback
Maybe you can recheck your package does it have fast ai package or not?
