Deep Learning Framework for 2.7?
1773
12-23-2020 10:08 AM
AndrewLaws1
Hello, I received a new computer with Windows and Pro v2.6 and I updated it to v2.7. I then downloaded the executable file for the Deep Learning Framework and it won't install due to not having Pro v2.6. Does anyone know when the Deep Learning Framework will be available for v2.7? Thank you!
DanPatterson
MVP Esteemed Contributor
No guarantee, but
Files :: Anaconda Cloud
it is doubly marked as main/pre-release, so they may or may not be done with it all
PS
make sure you read
DeepLearning_FAQ.pdf (esri.com)
to verify package versions
... sort of retired...
PeterKnoop
MVP Regular Contributor
Until it is updated, my workaround has been to:
  1. Make a clone the default Python environment in 2.7.
  2. Set that new environment as the active one.
  3. Fire up the Python Command Prompt, and manually install into that environment:
    conda install deep-learning-essentials -c esri
