Datum Transformation Issue
2472
12-17-2021 08:55 PM
Greta
Hi Esri Community
I have an issue with a Datum Transformation. A datum transformation can not be found in Australian GDA94 to GDA2020.
I downloaded and installed "ArcGIS Coordinate Systems Data" from My Esri and restart the computer, but the issue persists. In the dropdown list appear "None". Could you please help me with how to fix it?
2 Solutions
DanPatterson
MVP Esteemed Contributor
I suspect related to your concern
GDA2020 & WGS84 (Web GIS) - Esri Community
... sort of retired...
JayantaPoddar
Australian GDA94: Is this a Geographic Coordinate System?
Then, you need to use Define Projection to the layers with Australian GDA94 Coordinate System. Define their coordinate system as Geocentric Datum of Australia 1994.
Once this is done, you should see the appropriate transformation method(s).
Think Location
DanPatterson
JayantaPoddar
Think Location
