Database Layers Missing from Exported Layout
938
01-10-2022 12:01 PM
RJ17
I have a layer stored in a PostGis database on my computer.  When I export the map layout the Geodata layer isn't showing up in the exported file.  I've tried both PNG and Tiff exports at various resolutions.
The issue resolves if I export the database layer to a geodatabase and then use that layer in the exported layout.  Any advice why I need to convert?  This wasn't happening last week.
AubriOtis
That's really weird. Did you upgrade your version of Pro or PostGIS in the last week? What versions are you currently using?
Cheers,
Aubri
RJ17
Turns out when I added a new database connection to the same layer file it
worked. Not sure what went wrong in the old one.
