Customizing Dynamic Text in Layout
4877
10
06-11-2024 02:42 PM
ldoty_placer
I have a layout that displays a set of traffic accidents at a given intersection and must dynamically update the Primary Street, Secondary Street, From Date, To Date, and counts of injury severity based on the visible points in the map frame.
 I have three specific questions:
1) For Primary Street and Secondary Street, how do I display ONLY the attributes for the first row in my table?  I am currently getting a list of all distinct Primary and Secondary Streets visible in the map frame.
2) For From Date, how do I display just the oldest date?  For To Date, how do I display just the most recent date?  Again, I am currently getting a list of all distinct dates visible in the map frame.
3) For injury counts, how can I count different values from the same attribute field?  It appears I am not able to use iif() because it is only evaluating one row at a time, instead of treating all the points visible in the map frame as a table to be parsed.
The purpose of this layout is to create a custom print template in Experience Builder.  If there is a better way to go about this task as a whole, please let me know that too!
AubriOtis
Hi!
This is a really cool project. I think you need different kinds of dynamic text for some of these, and lots of SQL queries, which are supported in certain dynamic text elements.
Based on the information you provided I would try
  • Primary St: Value dynamic text with a SQL query
  • Secondary St: Value dynamic text with a SQL query
  • Start Date: If the map is time-aware, use Start time. Otherwise you'd have to use Value and a SQL query I think
  • End Date: If the map is time-aware, use End time. Otherwise you'd have to use Value and a SQL query I think
  • Count: Count dynamic text with a SQL query for your attribute or combination of attributes
Does this help at all?
Cheers,
Aubri
ldoty_placer
Thanks!
I think you are right about needing to use SQL queries. I'm used to seeing SQL as a language option but I'm only seeing Arcade in the Expression Builder. Would I just save it as a label expression file and import it? (I haven't done that before.) Or is there a way to add SQL to the Expression Builder language options?
[cid:[email protected]]
AubriOtis
I forgot to clarify, adding a SQL query is separate from the expression builder option. To access it change the Query type from all or visible to Custom query. That exposes the SQL query builder.
Cheers,
Aubri
ldoty_placer
I tested the Custom Query option for the counts and, while I was able to filter on the value I needed, it applied the filter to the entire table and not just to the points in the map frame.  Any suggestions on how to exclude the values not shown using the SQL query?
AubriOtis
Dang it, I forgot you needed only the visible to show up. There isn't currently a way to combine visibility and a SQL query. However, you are working with this for a print template right? There might be some additional things you can do in your custom print template code to make it work. Perhaps @TanuHoque can provide some ideas.
Cheers,
Aubri
TanuHoque
@ldoty_placer
Unfortunately ExB print widget doesn't support dynamic text elements at this point. Until they support this, please check out the below post, and you might find it helpful generate output from your print service with dynamic text element
https://community.esri.com/t5/arcgis-enterprise-documents/print-dynamic-text-from-a-web-application/...
ldoty_placer
Hi @TanuHoque. This is actually what I am trying to create at the moment, a layout with dynamic text in Pro to be exported. That is where I'm getting stuck. I'm trying to get the dynamic text to display specific information from the visible data only. The SQL queries I created are looking at the whole table. Any thoughts on a good way to tackle that?
TanuHoque
hi @ldoty_placer
does it work with from print service side with some simple dynamic text elements for you?
ldoty_placer
I haven't tried the print service side, yet. I've been focused on creating the layout in Pro with the dynamic content I need, first.
