Customize the Quick Access Toolbar
1513
09-04-2023 12:15 AM
aric
Hello everyone,
I use ArcgISPro and I would like to enhance the "ergonomics" to fit my workflow. My main issue - in order to do this -  is the size and accessibility of the Quick Access Toolbar which is located far from the work area with small icons.
Do you have a solution to customize this bar or otherwise by creating a new one which could, for example, stand out (floating bar?)  like the pane/sidebar do appear ?
Thank you all.
DanPatterson
This link
Quick Access Toolbar options—ArcGIS Pro | Documentation
describes what you can do, which I am sure you have seen
You can customize the ribbon as well
Customize the ribbon options—ArcGIS Pro | Documentation
... sort of retired...
