Customize default edting tool?
1916
08-18-2020 11:49 AM
MatthewMassey
Pro has a lot of customization options, which is super nice, but one thing that has always annoyed me is that default tools can't be changed...or...is there a way to change these? For example, I'd really like to change the default editing tool from straight line segment to end point arc segment?
Tags (1)
Scott_Harris
Hi Matthew,
In a feature template's properties > tools page you can set a default construction tool with this radio button:
Configure a feature template—ArcGIS Pro | Documentation
However, there is not fine grained control over which segment constructor is the default for a particular tool. You might want to post this over in ArcGIS Ideas. If you do, consider adding your use case - do you make lots of curves?
Scott
Scott_Harris
Hi Matthew,
Scott
MatthewMassey
That definitely helps some...but yeah, it would be super nice for complete control. Thanks for the reply!
MatthewMassey
And yes, curves are basically all i use...it's faster for our needs and the end product is more aesthetically pleasing.
