Custom Layout Templates
11467
13
10-10-2014 08:18 AM
JoeFlannery
Honored Contributor
Is there no option to use Custom Layout Templates in ArcGIS Pro?  We have put a lot of time into designing custom MXD templates and it seems that they are not accessible in ArcGIS Pro.
MarlboroughDistrict_Council
Hopefully 2.5 then
JodieParkes1
As Joe mentioned previously you can click on the Insert tab then choose the Import Map option to bring in an MXD.
I am just getting to grips with ArcPro and have produced a Layout File (i.e. template) on the Share tab from within a project.
The issue I am having is, when importing the layout file, all the text boxes I have created are showing oversized in comparison to what I originally produced. I am also seeing varying extents across map frames (even though they are set at the same scale)!
If you have any suggestions I would be very grateful!
Jodie
DavidWatkins
Esri Alum
Hi Jodie,
We haven’t seen any examples of this before.  Would it be possible for you to contact technical support and share a copy of your .mxd and .pagx file with them?
David
Amanda__Huber
MVP Regular Contributor
Exciting news everyone and Joe Flannery‌ -
This functionality was just released in the latest version of ArcGIS Pro 2.5
Customize your layout gallery (ArcGIS Pro 2.5)
