Custom decimals in labels
4659
03-19-2023 02:36 AM
teakplantation
In ArcGIS Pro 3.1 in the attribute table of my points feature class I have limited the decimals of a numeric field to 2 decimal places using the rounding option:
After applying the changes, the numbers display correctly in the attribute table. However, the labels on the map still show the full extent of decimals (see upper right of the image) without the rounding applied.
How I can achieve the same 2 digit display in the labels as in the attribute table?
Kind regards
DanPatterson
MVP Esteemed Contributor
Specify text for labels—ArcGIS Pro | Documentation
very inconvenient since label expressions don't use the same field delimiters as regular python
... sort of retired...
DanPatterson
teakplantation
Thanks Dan!
In my  case round(number($feature.RASTERVALU), 2) using Arcade 🙂
JerryJ
Using the script above, numbers ending with .00 are labeled without the .00, i.e., 29 not 29.00
