custom coordinate system SRID with PostGis
4806
5
04-25-2023 01:05 AM
Labels (3)
jherbst5
Hello all,
This is my first post here. I am just getting started with a PostgreSql/PostGis database in ArcGis Pro. I have successfully connected the database to ArcGis and I am able to move GIS data back and forth using various methods. However in the excavation where I work, we use a custom coordinate system and the GIS data from PostGis appears in Layer Properties>Source>Spatial Reference: Unknown Coordinate System. I have added our coordinate system to the spatial_ref_sys table in the database and its recognized by QGIS fine but not ArcGis.
I have searched around how to get ArcGis to recognize the SRID and found a couple of old posts from 2013 and 2018:
https://community.esri.com/t5/geodatabase-questions/accessing-a-postgis-table-with-a-custom-srid/td-...
https://community.esri.com/t5/arcgis-enterprise-questions/add-data-query-with-custom-srid/td-p/44299...
The posts mention a "back door" method of adding a custom system that ArcGis will recognize. Does anyone happen to know this method or any other way?
Thank you,
James
MelitaKennedy
Esri Notable Contributor
Hi James,
If you look at the files here: Github Esri projection-engine-db-doc objedit folder  and I can send you a document that explains it. Please drop me an email at mkennedy at esri dot com.
Melita
jherbst5
I see in some other threads for similar topics that @MelitaKennedy is the expert on such problems. I hope its ok to tag her here.
MelitaKennedy
Hi James,
Melita
jherbst5
Thank you Melita, I have sent you an email. Thanks for your help.
James
FabioNeiraAlzate
Hello Melita, Please, Can you share this document with me?
AlexanderGray
Honored Contributor
I too am having this problem.  Is there a solution to this?
