CSV
1416
07-23-2024 07:38 AM
MarcelSt-Germain
Since we can no longer import Excel table after removing EXCEL (no more driver said Pro and I can't find one to download, I try to do it with CSV.
I follow the instructions https://pro.arcgis.com/en/pro-app/latest/help/data/coordinate-conversion/import-coordinates.htm
Unfortunately, I only see a single coordinate to convert, in Coordinate conversion' not a way to parse to the CSV file I made.
What's I'm missing.
Lee_Butler
You can click on the Import button at the bottom of the pane to import a .csv file
MarcelSt-Germain
Tanks, forgot to look down.  Unfortunately, the csv file is not showing.
If ESRI had included the driver for EXCEL, it would be easier.
Lee_Butler
What version of ArcGIS Pro do you have installed? I'm using version 3.3.1 and I am able to open both CSV and Excel files in the coordinate conversion tool using import without having to add in any additional drivers to Pro.
MarcelSt-Germain
Exactly the same as you. 3.3.1.  No problem with arcmap.  Maybe, one day, Pro will be able to replace arcmap but not for me.
