Creating shp. from txt
3739
6
03-21-2024 04:48 PM
anxiousvole214
Hi all,
I'm having trouble creating a shapefile from a starting txt file. I've opened the table for the file and have added the fields of latitude and longitude (Float) but the problem is that, when I try to enter the instructed fields in the Calculate Field dialogue box, I get an error message.
Input table: PlotXY
Field name: latitude1
Expression type: Python 3
lat: !latitude!/3600
I've tried doing this for both latitude and longitude, but I keep getting a null field in both of them, and an error message pops up saying I have invalid fields.
I've spent days trying to figure out what's wrong and I've scoured forums and various help sites but nothing works.
DanPatterson
MVP Esteemed Contributor
why are you dividing latitude by 3600?
Decimal degree values are expected for latitude and longitude and the field should be a Double type, from there you can create geometry objects
... sort of retired...
anxiousvole214
Those were the instructions in the document. Float type, divide by 3600
anxiousvole214
I'll try this though
anxiousvole214
So I succeeded in getting past this last step. The fields of latitude and longitude now say 0 instead of null. In the contents pane, there is now a "Plot_XYTableToPoint" with a little green dot under it. How do I get this to a shapefile?
Dale_Honeycutt
There's always the XY Table To Point geoprocessing tool, but won't do you much good if your lat/long's are all zero.
Just spit balling here: What are the data types of your fields?  I'm thinking your input fields are text?  If so, try this expression:
 float(!latitude!)/3600.0
 If your longitude field is text, add another field of type double and calculate that field using float() as well.
I've no clue what the little green dot means -- never seen it.
anxiousvole214
I will try this, thanks!
