Creating Sequential Numbers via Attribute Rule in Pro for Enterprise
1161
05-01-2023 09:55 AM
DrewKirchner
Working within Pro trying to create a Database Sequence to be used for an Attribute Rule on a map that is referenced to our enterprise Portal. However each time I go to run the create Database Sequence I am successful but when I go to use it in my Attribute Rule it does not work and it produces an error basically saying that the Database Sequence does not exist. Is there a reason for this?
RhettZufelt
MVP Notable Contributor
Normally, that means you are not passing the correct name of the sequence.
are you just using something like:
return NextSequenceValue("SeqName")
How/where did you create the sequence?  SQL, FGDB?
R_
