Creating sectors
776
08-15-2025 05:31 AM
DavidMercer
Hi all,
I have a set of lines that denote a direction of movement.  I would like to create 45 degree sectors that are centred on each line (i.e.) 22.5 degrees on either side of the existing line.  I've tried the distance and direction tool but not sure if it's the correct tool for the job or if I'm not using it correctly - any suggestions?
DanPatterson
Basic code
import numpy as np
def _arc_sector(radius=100, start=0, stop=1, step=0.1, xc=0.0, yc=0.0):
    """Create an arc from a specified radius, centre and start/stop angles
    Requires:
    `radius` : number
        cirle radius from which the arc is obtained
    `start`, `stop`, `step` : numbers
        angles in degrees
    `xc`, `yc` : number
        center coordinates in projected units
    Returns:
      points on the arc
    start, stop = sorted([start, stop])
    angle = np.deg2rad(np.arange(start, stop, step))
    x_s = radius*np.cos(angle)         # X values
    y_s = radius*np.sin(angle)         # Y values
    pnts = np.c_[x_s, y_s]
    cent = np.array([xc, yc])
    pnts = pnts + cent
    sector = np.concatenate((cent[None, :], pnts, cent[None, :]), axis=0)
    return sector
Sample to give you an idea
radius = 10.
x_c, y_c = 0., 0.
line_ang = 45.  # your line angle/direction...
start, stop = line_ang - 22.5, line_ang + 22.5  # start and stop relative to it
ar = _arc_sector(radius=10, start=start, stop=stop, step=2.0, xc=x_c, yc=y_c)
... sort of retired...
DavidMercer
Thanks!  I'll give this a try
