Creating Multipart Objects
1017
12-11-2025 07:17 AM
JamesCarroll7
Hi all,
I have a polyline shapefile layer in ArcGIS Pro which shows the road system of a proposed development. All of the roads are on this one layer, but I want to break it down into different selectable sectors for different parts of the development. I used the Multipart to Singlepart tool to break down the shapefile, but I can't find a tool to allow me to select certain polylines to group together (I essentially want to create the equivalent of a block in AutoCAD where all the roads in Sector 1 are grouped together, all the roads in Sector 2 are grouped together etc.). Is it possible to do this in GIS?
DanPatterson
MVP Esteemed Contributor
not sure if you want the features to remain in the same layer or not.  If you want separate layers for each grouping see
Split By Attributes (Analysis)—ArcGIS Pro | Documentation
or if you want to split by using another geometry layer Split (Analysis)—ArcGIS Pro | Documentation
The opposite of multipart to singlepart is
Dissolve (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
DanPatterson
JamesCarroll7
Many thanks Dan, that worked a treat. I do need all of the multipart features to be in one layer, but I used the 'Merge' tool to do that once I had all the multipart features created.
DavidSolari
MVP Regular Contributor
Like Dan said, Dissolve with the "sector" field should be enough. If you need a more specific workflow, here's an arcpy function that'll condense a bunch of geometries into one multipart:
import ujson
def reduce_geoms(geoms: list[arcpy.Geometry]) -> arcpy.Geometry:
    iter_geom = iter(geoms)
    first = next(iter_geom)
    assert first.type != "point"
    retval = ujson.loads(first.JSON)
    has_curves = "curvePaths" in retval
    path_key = "curvePaths" if has_curves else "paths"
    for g in iter_geom:
        gson = ujson.loads(g.JSON)
        paths = None
        if "curvePaths" in gson:
            paths = gson["curvePaths"]
            if not has_curves:
                retval["curvePaths"] = retval["paths"]
                del retval["paths"]
        else:
            paths = retval["paths"]
        retval[path_key].extend(paths)
    return arcpy.AsShape(retval, True)
JamesCarroll7
Thanks for that David, very helpful, I appreciate it!
