Creating Features
1705
03-08-2023 07:50 AM
JohnnyZiem
My question is about creating new features and measuring.  There are times I need to measure a length on a line (or pipe in this case) and at a certain footage, I need to create a line feature.  But when I am using measure tool and then switch to create, the measured line disappears so now I do not know where to place the new line.  Is there a way in Pro to measure a length and denote the end with a symbol?  Or can I measure AND create a line at the same time?  thanks!
CarlMorrison
If I understand your question, you would like to create a line feature at a specified length and direction.  Have a look at the Direction/Distance command available after selecting the first vertex and a right click.  https://pro.arcgis.com/en/pro-app/latest/help/editing/specify-a-direction-and-distance.htm
JohnnyZiem
thank YOU!
Scott_Harris
@JohnnyZiem
Along with @CarlMorrison said, you may also consider using the Trace tool to trace along another line for a specified distance.
GIF:
JohnnyZiem
thank YOU!!!!!!!!!!
