When a create a tin, I need extent it to a other feature class, but the maximun extent is the input data. The option of extent it's this only for definite the minimum?. I definite in enviroments a extent bigger the input data
Whether the extent is specified or not, extrapolation into an area of nodata isn't going to work.
OK Ok , thanks for your fast and clear help. 👍
