Create Spatial Sampling Locations using 2 sampling methods: systematic & stratified by polygon
724
02-25-2026 01:26 AM
JoeWoodall
Hello, I am trying to generate a predetermined number of systematically located sample points across multiple polygons.
I have been able to create randomly sampled points using Create Spatial Sampling Locations tool stratified by polygon and setting Strata Sample Count Allocation Method to a population field.
However, I cannot see how to achieve systematic sampling within each polygon.
Any advice appreciated, thanks.
DanPatterson
MVP Esteemed Contributor
What parameters are you using in the tool?
Create Spatial Sampling Locations (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
JoeWoodall
Thanks for the response Dan. The below settings look to do what I need but with random rather than systematic sampling.
Input Study Area: woodland polygon layer
Output Features: default
Sample Method: Stratified by individual polygon
Strata Sample Count Allocation Method: Count equal to population field
Population Field: Plots (number of plots per polygon)
Minimum Distance Between Sample Plots: default 0
DanPatterson
Not sure, but looking at the parameters, I suspect some of the "optional" parameters are only available depending upon the sampling method chosen and not available for others
KenBuja
I created the Sampling Design Tool add-in for doing more complex sampling. Take a look at its documentation to see if it has the capability to do what you're wanting.
