Create Random Points Tool, Minimum Allowed Distance and Overlapping Points
2828
6
08-16-2022 04:07 PM
LucasBeck
I was using the "Create Random Points Tool" to distribute random points within polygons, and I have a question about the "Minimum Allowed Distance" field in tool interface that I am hoping the community can answer.
For my analysis, it does not matter how close together the random points are, so I left the zero in "Minimum Allowed Distance" field. However, I would like to know if this means that the random points that I have generated could potentially overlap (have the exact same coordinates) or if the points would be distinct just with no set minimum distance required to separate them? Thanks so much.
2 Solutions
DanPatterson
MVP Esteemed Contributor
Points would be distinct features, but they could overlap, that is, have the same coordinates.
... sort of retired...
DanPatterson
Find Identical (Data Management)—ArcGIS Pro | Documentation and if you need to delete them
Delete Identical (Data Management)—ArcGIS Pro | Documentation
on the shape field if you have the appropriate licence.  If not, you can use the calculate geometry attributes tool and add the x, y coordinates, then sort on those fields and examine.  Unfortunately, sort on geometry requires an advanced license also.  At this point you need to export the featureclass and more is needed.  If you don't have an advanced license, I can provide more info.
DanPatterson
LucasBeck
DanPatterson
Please don't duplicate posts
LucasBeck
Hi Dan,
Thank you for your answer. Do you know of a tool I could use to look for overlapping points?
Sorry about the duplicated post, it won't happen again.
DanPatterson
LucasBeck
Thank you so much. This seems to be working great!
