Label expression not honoring number formatting in geodatabase table in ArcGIS Pro 3.0
2674
08-16-2022 11:08 AM
BarbaraThigpen1
In ArcGIS Pro v 3.0, label expressions are not honoring the formatting that is in the table. For example, there is a field with numbers with 4 decimal places, in the formatting options for the field I have chosen 2 decimals and to pad with zeros. The number appears correct in the table, but when it is labeled it shows the number with the 4 decimal places and not what is in the table.
BarryNorthey
Rounding an attribute table field value does not round its related label. Both methods are explained here:
https://support.esri.com/en/technical-article/000025170
This Arcade label expression rounds polygon label field Shape_Area to 2 decimals.
Round($feature.Shape_Area,2)
